Aug 10, 2005 #1 G gazza_new Limp Gawd Joined Jun 20, 2005 Messages 162 I'm getting 42C on my ASUS A8N-Premium in my Antec P180 case! Airflow seems ok, but all fans are on low! How does this rate?
Aug 10, 2005 #2 B Betauser 2[H]4U 2FA Joined Jul 14, 2003 Messages 3,872 sounds about right to me..i have the same mobo and it's really hot where i live right now.. and i'm getting the same temp.. 40-42c
Aug 10, 2005 #3 M magoo [H]F Junkie 2FA Joined Oct 21, 2004 Messages 14,705 i have the Deluxe version. The room is about 80 F and when the system is full on my temps on the cpu run 42-43 C and the board itself runs about 38-39 C. My cpu fan runs about 3800 rpm or so. What CPU??
Aug 10, 2005 #4 J JadeDM Limp Gawd Joined Mar 7, 2005 Messages 291 got the deluxe version also with the new styled fan from asus. Run at a constant 38-39 C under load and 36C on idle
Aug 10, 2005 #5 G gazza_new Limp Gawd Joined Jun 20, 2005 Messages 162 I'm running a AMD 4400+ which is at 35C idle at the mo!
Aug 10, 2005 #6 S Shzitt Limp Gawd Joined Aug 12, 2004 Messages 341 Processor 32 idle, 40 load Board 33 idle 41 load. AMD 4000+ stock cooling.
Aug 10, 2005 #7 0 0810 2[H]4U Joined Jun 13, 2005 Messages 2,779 i have the regular A8N-E, and everest and speedfan says my mobo is at 25C
