Asus A8N-E voltage help
is there any way to change the settings on the voltages on this mobo?
the voltages for the fans?
all my case fans are connected to it and I want to slightly underpower them because they're too loud at the moment.
any help is appreciated
no you cant change fan volts on the motherboard...the fan controller only works on the cpu fan and not the case fans...you have to use a seperate fan controller for what you want on that board..I owned that board for 1.5 years and i enjoyed it very much...
