ASUS A8N-E chipset fan broken
deadman_uk
I have an ASUS A8N-E motherboard but today after a series of 6 beeps, the POST screen alerted me that the chipset fan was spinning low or was not spinning at all. I looked at the fan on the motherboard and indeed it was not spinning. When you power up the computer, it tries to spin but stops, and when you power down the system, it moves as if it was trying to stop.
What can I do? the motherboard is under warranty and the fan is clean as far as I can tell but it will cost me a lot of money and time to send this back, can I buy a 3rd party fan? or request one from ASUS?
You can call asus on the rma number and give them the info.they will mail you a replacement fan for free.3rd party coolers work wll too.i used the zalman heatsink
nb47 i think ,the blue one ,and i cut the taller fins off level with the lower ones and mounted a 40mm 5k fan on top and it works great.the heatsink mounts like it was made for it.i now have a 40mm blower on top of it with a fanmate controller and rpm's range from 4k-8k.at 5000 rpm temps stay at 32-35c.they are alot cooler than using the asus one.the asus one always ran 40-50c.still within specs but i like it to run cooler.there are alot of posts with this problem so call asus and get another one.you have to remove the motherboard to change it though.the thing i like is with the zalman heatsink i can change the fan without removing the board.also coolermaster makes a heatsink too that comes in gold or silver and mounts the same way as the zalman.the fins are all even and no cutting is required.some people run the zalman with no fan and temps stay within spec too.
A third-party cooler will work... putting in another Asus-spec cooler is asking for it to fail within a few months time again.
wesleys_dad, your sig is about twice the legal length and has been so for a while... fix it?
not really.
There was a bad batch of fans put onto the early revision a8n-e's. They send you a different fan when you ask for it.
There is no reason to spend money on something that you dont' have to.
I took the fan out of the original heatsink and set up a spare case fan to blow on it until I got the replacement.
I had another look at the fan and I think its dead. It looks like I have 2 options...
- Buy a 3rd party fan
- Contact ASUS and get a replacement fan
I have some questions though...
1) If I stick a 3rd party fan on the motherboard for example this
Zalman ZM-NB47J Northbridge Cooler [size=-1]
http://cgi.ebay.co.uk/Zalman-ZM-NB47J-Northbridge-Cooler-Heatsink-5-24-Inc_W0QQitemZ330018013607QQihZ014QQcategoryZ101194QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
will it fit my motherboard)? and will it void my warranty with ASUS?
2) How would I fit the new fan (whatever one I choose)? How do I remove the old fan? I dont feel confident in removing the motherboard, I dont like the idea of that. Is there a way to remove the old fan without removing the motherboard?[/size]
the NB47J fits my friend`s A8N-E FM mobo perfectly. The only problem is, the uber-hot chipset runs even hotter with a passive heatsink, so he had to use an elastic band to affix a 50mm fan to the side.
No problem whatsoever afterwards, as far as I know.
I'm guessing the A8N-E FM is different than my A8N-E?
So you are saying the NB47J is actually less efficient than the stock ASUS fan? That is no good then, what about this? Will this provide good cooling?
Zalman ZM-NBF47 Northbridge Cooler Heatsink
http://cgi.ebay.co.uk/Zalman-ZM-NBF47-Northbridge-Cooler-Heatsink_W0QQitemZ140013294152QQihZ004QQcategoryZ101194QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
TMan1876 said:
not really.
Yes really. The new fans are prone to failure too, but less so than the original revision.
Technically you will void the warranty if you get a 3rd-party solution, so if you're intent on preserving your warranty (I often void the warranty on things as soon as getting them), give Asus a call. The Zalman NB47J should fit... but it'll be a tight fit against your video card. It might run a little hotter than the puny little fan+heatsink combo, but it'll never fail again and will be effectively silent. The NBF47J is too big, imo.
Do you know alot of people that have had the replacement fans fail too?
Everything is prone to failure to varying degrees... even (gasp) any aftermarket heatsink and fan combo.
I use the zalman with a 40mm blower fan on it and my video card is a powercolor x800gto and it clears the heatsink and fan with no problem.if your card is the same youll be fine.
