ASUS A8N-E Bios questions.......
chrisyak
I am just workin on my new rig, first build ever.I am doin some wire management right now so i figured i would ask for some heads up before i get to it.Don't mind me i am a newb...LOL.......
What are the best or most stable bios for the A8N-E(1008,1009,1010)?Also updating to the nforce chipset 6.66 is good idea i take it ...lol.....
Also i am kinda new to the bios flashing is it fairly easy?......is their any newb manuals on doin this(he,he)?????
Any advice or tips about this board would be greatly appreciated..........
X2 4400/ASUS A8N-E/Zalman 9500/2GB Crucial Value Ram/ATI X850 XT PE/400GB Deskstar Sata II /X-FI /CM Stacker
I can't really help you on the newer versions of the BIOS. When I first got my board quite some time ago, it came with the 1001 BIOS. I have updated it to the 1003, but have not updated it since. It's woking great so I don't see a need to mess with it at this point.
Here is a link to the procedure on how to flash your BIOS.BIOS Flashing Choose the AWDFLASH BIOS Update Procedure. It's fairly simple. I'd recommend having your PC plugged into a UPS while flashing your BIOS (if it isn't already) just in case. It's a very straight forward procedure.
You definitly need to update the chipset driver to the newest version or at least version 6.65.
SIGH.............
Ok I have a 3200+ OC'd in this rig. I run the bios version 1006 and use the 6.65 drivers.
Here's the tips I know when installing this system.
When you get your board with 1001 install XP.
Then install the drivers on the CD. This will resolve a ACPI dll that 6.65 doen't know about.
Reboot.
Upgrade to ver 1005 or greater. Good luck there are several threads on Anandtech and Asus website that have info on 1008 and up.
Uninstall all the Nvidia drivers.
Reboot.
Install 6.65 or 6.66 drivers.
Reboot.
Install video drivers.
Reboot.
Install all the XP updates.
Reboot several times.
Finally work on OCing your system if you want.
Good luck if you own this board.
If you are looking for a board go get the BFG one or something else.
I'm looking into getting another mobo+cpu combo. Preferrably BFG or DFI if you want to OC.
