ASUS A8N and PSU
Filter
ok i have a 20pin antec PSU do i have to buy a 24pin atx now i think i may have overlooked this.
also if i dont how do i plug it in. do i plug it in where 2 extra holes are on each side?
If you plug in a 20 pin PSU, the bottom four holes on the 24 pin plug on the motherboard will be empty. The first 20 pins of the motherboard's connector are keyed just the same as the pins on a 20 pin PSU plug, so you can't plug it in wrong, it will only go in one way. (Otherwise, if you're forcing it, your in the wrong holes. ;) ).
Now, you may hit problems...in fact to be honest I think you will hit problems with a 20 pin PSU when it comes to stability, maybe even problems finishing the Windows install, but that might depend on if you're using two video cards right now, or if the cards have a secondary power plug. If they don't, like let's say you're using 2 6600GT's, or have 2 6800 Non-Ultras that don't have the six pin power plug, good chance you'll be stable. If it's 2 6800 GT, Ultras, or if you bought used cards from an old Dell, 2 6800 GTO's, then I suspect you might not be as stable.
Give an example, I started out with a 510 Watt PC Power & Cooling Deluxe, a 20 pin model. Wasn't super stable. I'm running an A8N-SLI, 2 6800 GT's and a FX-55 CPU. Switched to a 510 Watt PC Power & Cooling SLI, same PSU for amps and wattage, just 24 pin and has 2 six pin connectors for the video cards, now I am stable. Switching from 20 pin to 24 pin helped.
A 20 pin to 24 pin converter won't do too much, I had one of those, then went to just having the 20 pin directly in the motherboard. What helped some when using a 20 pin is making sure each video card had it's own set of molex plugs going to the dual molex to six pin converter cable that came with each video card. That got me from "really unstable" to "not too bad, but still not wonderful".
But again, with one video card, or two that don't require a secondary power plug, this could very well be moot.
Have seen that the people who are stable with two video cards drawing a lot of power a) Have at least 510 watts, b) A 24 pin PSU and c) At least 30 amps on the 12 volt rail.
