Asus A7V600 - Disk access causes lock up
I have an Asus A7V600, BIOS 1008, with an AMD 3200+, NV 6800, Audigy 2ZS, Linksys wireless "G" LAN, and two PVR-350's. This is a fresh install - the three HDDs were all fdisk'd and formatted. I have two SATA drives and one IDE. I installed the system first with just the primary SATA. After Windows was installed I setup the seconds SATA drive and then a single IDE. I've set the boot order to "ATA device" first. Windows identifies the IDE drive as "Drive 0", the SATA OS drive that I installed first as "Drive 1" and the other SATA as "Drive 2". The problem seems to be that whenever I try to access HDD programs, such as Diskeeper or Windows Disk Management, the PC hardlocks and forces me to reboot. No BSOD and when I get back into Windows, it doens't know that it's recovered from a fatal error. When installing the system, I used all newest drivers off of the manufacture's web site. I'm not OC'ing.
If I try to install the system over again, with both SATA and the single IDE drive, Windows will try to install the OS on the IDE even though I tell it to install on the SATA. Although it doens't place the any Windows files on the IDE drive, during the install it tells me that it needs to also format the IDE drive so it can place files on it during the setup process. And then at the end if I tell BIOS to boot from the SATA first and remove the IDE from the boot process, it'll fail to find the OS (even though Windows was placed on the SATA drive.)
Another weird thing is that when Exploring the SATA/IDE drives I'll go X layers deep into folders and then it'll start to take around 20 to 30 seconds before it'll open the folder and display contents. But if I go back up a layer, those top layers will respond in a normal/quick way. :confused:
By telling the comp to boot IDE (PATA) first, you're automatically assigning IDE0 (or C:) to the IDE disk, and then D: to the SATA disk. The bootloader is on C: (the first disk, IDE0) by definition, which is why it needs to format the parallel drive, and also why it doesn't find the OS if you change the bootsequence. You need to figure out how to tell it to boot SATA first (since it's part of the chipset, I doubt it will be SCSI), and then install Windows anew on the SATA disk.
Right, agreed. That's what I did. I removed all drives (the extra SATA and the IDE) and only had one SATA. During the OS load I hit F6, specified the SATA driver, then continued. Windows installed. Then after I fully installed Windows I installed the two other drives that I had first removed (IDE and SATA). Windows is fully installed on the SATA drive.
I think you misunderstood. It doesn't matter in what order you installed- by telling it to boot to ATA, it is assigning IDE0, C:, to the parallel disk EVERY TIME IT BOOTS. You need to figure out how to boot to SATA first in BIOS.
For relevant material, see pages 58 & 63 of the manual for your motherboard. The topics in question are "Onboard SATA Boot ROM", "Onboard ATA Device First" (both on 58) and "IDE Hard Drive" (on page 63), though it probably doesn't involve all three of these- more likely 1 and 3 only.
