asus a7v333
umcpgrad
I thought it supports usb 2.0... but it seems like it doesn't... does anyone know where I can download the driver for usb 2.0??
and is there anyway to upgrade bio version through asus's old update anymore?? :(
I want to hold back in upgrading my whole rig.. so I need help thanks.. :)
The V in a7v333 means VIA. Get the VIA 4 in 1 drivers at viaarena.com and it should include the drivers. If not, go to www.asus.com and look up the mobo in their driver database.
Assuming you use Windows, is it XP? Do you have the service packs installed? Read this about USB 2.0 and Windows:
Linky-poo
If you're using another version of Windows (like 2000), service pack it also.
I also second malingjc's advice about getting latest 4-in-1 driver's.
Mr.Dearthian
i've got one of thoes (see sig) and the USB drivers were on the mobo cd that came w/it. :)
