Asus A7S333 and 2000+ Heat Issues.
jubs
Hi I have an Asus A7S333 and XP 2000+ and my SiSoft Sandra reports 61C and I know this is true because of freezing. I am going to replace the heatsink and add some more ventilation but I think I may have found another source to the problem, too much voltage to the chip. It runs on AwardBIOS version 1003 and from Sandra it says my VCore Voltage is at 1.75V where the chip should only need 1.6V. The problem is my BIOS wont let me decide the voltage that goes to my chip. What can I do?
SiSoft Sandra never reports correct settings.
Install Asus Probe which is much more accurate.
Yes this is true but when I go into my BIOS I get all the same readings, VCore at 1.75V and CPU temp at 60C.
