Hey everyone.
I'm in the process of putting together a cheap system for my friend's aunt. Its her first computer ever and she wants to get into a lil' bit of everything.
I've had a couple of issues with the motherboard though and its really bugging me.
Here are the specs:
AMD AthlonXP 2400+ (266MHz)
ASUS A7N8X-VM/400
512MB Samsung DDR400
WD Caviar 40GB 7200rpm 8MB Cache
LiteOn 48x24x48 / 16x DVD combo drive
350W ATX case
MS Internet KB & Optical mouse
Anyway, the first issue I came up against was WinXP Home Edition constantly bluescreening during the install. I swapped out the Samsung DIMM (which I purchased against my own better judgement because the exact die number (K4H560838D-TCC4) ASUS Qualified Vendor list) for an old Micron PC2100 DIMM and everything worked fine. Also I was getting a lot of artifacting onscreen while I was using the Samsung RAM - probably because the integrated video didn't like it.
So I resigned myself to seeing if I could RMA the RAM... Which I'll tackle tomorrow morning.
Once everything was finally up and running, I yanked the network cable from my own computer and plugged it into the integrated LAN port on the ASUS Mobo.... no lights. wtf?
It says "Local Area Connection - A Network Cable is Unplugged" no matter what I do.
I've tried tried disabling and re-enabling the ethernet port in the BIOS, but that just makes it so that I don't have any Network adapters listed at all. After re-installed the nForce Unified drivers, the problem is exactly the same. grrrr. I've gotten around the problem by digging up an old 10BaseT NIC and using that instead of the onboard LAN.
On to the next problem...
While confirming that everything was running okay / burning in the system using SiSoft Sandra 2002, I found that whenever I run the memory benchmark the bottom half of my screen becomes all skewed and grainy. This only happens while the memory is being stressed by the benchmark, as soon as the benchmark finishes, everything goes back to normal. Is there something wrong my the way the motherboard is sharing the system RAM with the nForce2 IGP?
I currently have it set to reserve 64MB of RAM for video and have the AGP aparture set to 128MB.
Any suggestions?? I'm stumped! <sorry for the long read, if you read it
Here are the specs:
ASUS A7N8X-VM/400
350W ATX case
