Asus A7N8X-E Deluxe Issues? Help
SoulWind
I recently upgraded from a MSI KT3 Ultra 2 (Via KT333 chipset) to a Asus A7N8X-E Deluxe mb. My system is a Athlon XP 3000+ (Barton) with 1 gb of DDR 400 (2x 512mb) with 1x LG 4120 DVDRW, LG CDRW, 2x WD SE hds, ATI Radeon 9500 Pro. Since I switched motherboards I have noticed occiasional sound issues, most commonly noticed when listening to mp3s, there will be this occasional slight stutter every 10 seconds or so, and it appears to happen most commonly when I am typing, I tried my old SB Live X-Gamer 5.1 in place of the onboard sound and the issue was even worse, one of my thoughts is could it be a power issue, one thing I have noticed that did not occur on my MSI board is that when the DVDRW for example is under heavy use, the LED fan for my CPU flickers, it also happens when the hd is under heavy use (ie defraging) The board came with 1009 bios and it occured then, and occurs on the newest 1013 bios. The voltages in asus pc probe appear fine, however one comment is that the cpu is running about about 1.69 volts instead of 1.65 even though I tried setting it manually to 1.65 in the bios, also I've seen it bounce to 1.71 before. Another issue is that with the nVidia nTune or nVidia System Utility I can not access the voltage settings My power supply is an SPI 400watt PS which is AMD certified..
If anyone has any thoughts of whats going on or what I should try, please post.
Also, on a side note I am using the newest nfrorce driver package from nvidia and the newest nforce audio/soundstorm drivers from nvidia also, the issues also occured using the version of the audio driver included in the nforce driver package
I haven't had problems like that. What's your CPU usage like when doing that? What app?
cpu can be basically at idle, I'll typically have nothing open accept mIRC, MSN, and say be typing to someone on MSN while winamp is playing, happens with both the directsound and waveout plugin in Winamp 5, and as I said it happens with my SB Live X-Gamer 5.1 even worse, also its worth noticing that the problem is OCCASIONAL it doesnt seem to always do it seems to vary from reboot to reboot
also, not sure if anyone else has tried an LED fan as their cpu fan (I've got a coolermaster blue LED fan on there) and noticed any flickering like I have
I had an LED fan with no problems. I use to have one of those IM clients (MSN does did it too) open that would screw up the audio, I use Gaim BTW now with none of those issues.
I've also noticed the audio stutter while watching video, so I'm fairly certain its not a MSN issue
Well my Asus board has given me no issues at all. If all else fails, I would try reformatting/reinstalling windows.
hmm, well I can always give it a try at somepoint, also if noone knows whats goin on with my flickering cpu fan and dont think its a board issue, any ideas why I cant adjust voltage from in windows or why I cant get the thing to actually run at 1.65
1. the overvolting of vcore that you see in probe compared to bios is normal.. not to worry
2. are u using the onboard sound or the sb card?.. had a friends pc i put together with a7n8x with sb audigy 6.1 and i also got stuttering.. i solved it this way..
a. i made sure i disabled the onboard sound in the bios (do not if u intend to use.. of course)
b. make sure that the sb live (or the on-board soundstorm) is active or selected in your sound properties(sound playback) in control panel.
c. and of course i made sure all the drivers were up-to date.. from what i understand that creative recently released as of like 1/2/05 a new and much improved driver set..
d. maybe its your psu.. got another to try?..
on a side note.. i noticed your overclock.. may i suggest lowering your multi and raising the fsb.. i believe your underclocking your ram.. you do have pc3200(ddr400) it is made to run at 200(fsb).. just a suggestion.
hope it helps.. let us know your progress
thanks for the tips I'll have to give it a try, also yes I know I am underclocking my ram, its so when I OC the ram doesnt exceed 400mhz (I havent played around with ocing this much due to these issues) the chip is running stock atm, its the 333mhz FSB version of the 3000+ so the clock is a little higher, also it is multiplyer locked so adjusting the multiplyer is not an option and I dont really feel up to trying to unlock it :p
unless you meant the 1mhz OC heh, also you mention new drivers for the live, if you know where to get some that would be great, as far as I can see the newest drivers from creative for the live is 28 Feb 03
sorta, SPI , or Sparkle Power Inc. is not a premium PS or anything, however it is a very well known and established brand for good PS's, theoretically one should have heard of them if your big into hardware, I have noticed recently that they are now part of the FSP group, much to my dismay.
my badd.. it looks like the audigy series has a driver package that came out a week or so ago.. i do not own a pci sound card myself its jus something i came across while forum browsing... so scratch that idea...
psu: is it this one?
spi 400w
if so it should be ok for your purposes.. a little low on the +12v amps but i've seen these work ok on many systems.. personally i don't think your prob is with the psu.. i could be wrong so do not rule it out..
try some of the other tips i mentioned above.. and let us know..
yep I'll give it a try, yes that is my PS, after you mentioned it I read around a few sites and apparently there are some modded audigy drivers for live's coming, I'll be hoping to give those a try at some point, Thanks for all the help
that is what I had thought might be, I'd used the PS without issue before, I'm wondering if theres something wrong with say the voltage regulator on the board, however I am unsure and I will be trying the suggestions people have provided and we will see the results, just working on finishing some stuff up before I start really messing with my system
I have the same motherboard and had crackling in a few games due to the southbridge being too hot.
the southbridge? really, thats interesting, my (as I am sure anyone elses) videocard's cooling would be washing right over the southbridge, tho I cant imagine that is my problem as it seems to happen even when I've been doing nothing on the comp and just at the desktop
