ASUS A7N8X - DLX "System Failed CPU Test"
Erland
I tried to use the search function but it's disabled by admin...and The Sticky up top I havn't quite got through yet....but here is my problem
No matter what CPU or Bios I put in my board I keep getting the speech post reporter(which is disabled but still talking) saying
I have a "1700+ B" and a "2100+ B" and no matter which one I put in the same thing happens. I have even tried going back to the original BIOS but nothing seems to work. I tried default settings to aggressive to optimal but after a while it will still repeat it...and the only way I can get it to stop is put in another soundcard. I had everything working for several months then one day this started and I can't figure it out...
I had it overclocked to a 170FSB when it started so I lowered everything back to default and it works fine until something extreamly graphical happens, like playing a game like Need 4 Speed but only once all 4 cars are on the screen and they go through water or something like that. Once it happens it will repeat it until you reset the comp. I thought it was my graphics card but I upgraded to the GeForceFX 5200 from my GeForce3 TI200 and it still does it. I even tried moving my RAM from daul channel to single channel and all that does is make it take longer before it says it. I even tried to raise the CPU/RAM volts but still no go.
I loved this board until this problem arised and now even with speech post reporter turned off it still yells at me and there is nothing on there site about it....AAAAAAAAAHHHHHHHHHHHhh....
Thanx for any help.
3r14nd
Specs:
ASUS A7N8X-Dlx v1.04
1007D-Uber.rar BIOS
Thourogh Bred B 1700+/2100+
11 x 133FSB
Vantec Iceburq on Northbridge
PASV Heatsink on Southbridge
AS3 on all heatsinks
SLK-800U & Tt Smartfan2 wideopen
CPU Temp 38c / System Temp 23c
2 x 256mb Kingston Hyper-X PC3000 5-2-2-2
40GB 7200 rpms Maxtor Harddrive
GeforceFX 5200
Generic Keyboard
Logitech Mouseman
Microsoft Sidewinder
Lexmark Z-23
On-board:
LAN
Sound
have you reset the bios? There is also a setting to disable this. I will reboot here in a minute and find it for you. Also, are you sure your stable at any speed? Have you run prime....
PS.....your ti200 is faster than you FX
Reset BIOS many times.....
Flashed BIOS to EVER other version....Org and UBER...
Speech Post Reporter = Disabled - Still gives me error...
Prime95 Triggers the error when OCing and when I reset BIOS to default....but Prime95 never REPORTS errors
Got the FX for Free...so I thought why not...might as well try..
The TI200 will not run at default speeds have to underclock it..? That's another Problem...
what about quickt post (not the name but close enough). Thats the only thin I can come up with right now. The answer is in the manual (at least for the rev 1.x boards. I had the same problem on my first two boards and I know I found the answer in there. I would check but I dont have it anymore.
So far....
I went and read the F*ing manual AGAIN and found something I didn't before.....
System Failed CPU Test = Check to make sure CPU is installed corectly
So I went and pulled my HSF and cleaned my proc and CPU....
Sprayed it with canned air...(mobo, hsf, fan, cpu)
noticed on the cpu there was some AS3 from the HSF...
When I tried to apply the AS3 again to the HSF and noticed that when I appiled it that the AS3 got on the little pads and those pads sat right on the bridges. (maybe shorting them out causing error)
started it back up and everything ran smoothly.
turned case right side up....
overclocked back to normal.....(11x170)
ran prime95 for hours and it finally repeated the error only to lock up
reset....
changed fsb to 11x166
still waiting.....but so far sounds good....
I also rasied my
chipset volt = 1.675
cpu volt = 1.7
will update you tomorrow if anything changes...
cool. Hope that fixed it for you. I know how annoying it was the first time I saw it.
Still no go....
after several hours it said it once.....then locked up...
restarted....
several hours later.....said it again, and again, and again, till lock up.....
restarted....
said it on startup and locked on windows screen....
now i'm at school and will test out different things when i get home...
