I have a problem with my A7N8X board. I just got back to school from my break and plugged in my computer (my computer was sitting unplugged and covered with a sheet over the whole break) and I found I had problems. First I couldn't get into Windows. Right when it got to the Windows XP screen with the thermometer bar.. the thermometer bar would go once and then you'd see a split second of the blue screen of death and then it would restart. I finally formatted and I can get into windows now.
My problem now:
I have an AMD Barton 3000+ and now my computer is only reading it as a 1300+. It should work at 200mhz and a 15 multiplier and I set it in the bios but it doesnt seem to do anything. Another thing is whenever you exit the bios, it seems to restart but the screen goes black. It also does this when you restart it from windows. What I have been doing to get it to work is just hold the power button till it turns off and then turn it on again. For a while the bios wasn't even saving my settings that I changed to it so I might be dealing with a low or dead battery. Windows seems to be working fine and everything is installing properly and I'm on the internet and all.
Pretty much my only two problems now is:
1. My CPU speed isn't being read correctly (it can't be a jumper problem because it worked fine before I left school and I or noone else has touched the inside of the case since then).
2. My computer doesnt seem to be restarting right whenever I tell it to.
If anyone has any suggestions that would be great. I really need to get this resolved.
Thanks for reading and I look forward to a response.
My problem now:
