ASUS 9800xt Temp Montoring
Ubermouser
Is there any way to monitor the temperatures with software of your ASUS radeon 9800xt without Smartdoctor? It screws up the OMEGA's driver settings.
I'm hoping the solution works with Motherboard Monitor 5, or is a plugin of such.
Reason being is that I dont understand why the fans on the card arent spinning.. it isnt a real problem because it can go up to 440/400 without artifacts, but I bet it could get much higher if those fans were spinning.
Another question: what is the most effective air cooling capable of being attached to the 9800xt? and, do Core and mem voltage mods have any negative or adverse effects on a Radeon 9800xt? thanks.
