Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I had one for a bit but I didn't have any problems with it. One thing I will note is when the fans spin down the radiator does get pretty hot so you may want to use a custom profile and disable spin down if that is something you are worried about. I didn't bother replacing the fans or modifying it in any way.
Got one. Works fine. Gets hot as shit where that radiator outputs though! I second D-EJ915 - I used afterburner to keep the fans from stopping, or the top of my case would get mighty hot (OL-11 XL).
