asus 670, vs 7970?
I'm building a gaming computer.
Newegg has the asus 4gb gtx670 on sale for $414 right now (minus $20 rebate.. but that's 6mo away!), on par for price with the 7970.
I'm running a single 1080p monitor (not 3 screens).
I've read that 4gb vs 3gb won't make a difference, but, I've read that the 670 might run skyrim better.
With the 670 being the same price, would you choose it, or still go with the 7970?
Complete aside, but not worthy of its own thread really:
I'm recycling an i7 920 cpu I already have (and putting all my funds into the graphics card :) ). I'd like to overclock it to 3.5ghz-- something better than 2.67 anyway.
I already bought a HAF 932 case, which comes with a single 140mm fan, and 230mm fans everywhere else.
I'm looking at plug'n play water cooler setups, and they're all single 120mm, or dual 120mm. Can that mount easily onto a 140mm space?
Or, do I need to get water cooling at all-- or is a quality air cooler going to get me all the cooling I need to overclock a 920 to 3.5ghz? (feel free to make recommendations!)
thanks!
-Bernard
Well......
I have two gaming boxes.
One is dual 7970s.
One is dual GTX 670s.
If all you are going to use is a 1080p monitor, and never consider larger or Surround/Eyefinity then the 670 will do you just fine.......
That said, the 7970 has a bit more giddy-up and with the newer games on the horizon (last light) it may be a better choice.:D
If you have a quality air heatsink and are only going to 3.5 with the 920, I'd leave it at that.
If you want more, the buy one of the Corsair all-in-one single fan deals, I think they make a 140mm single radiator all-in-one now.
here's a link: http://www.performance-pcs.com/cata...oduct_info&cPath=59_202_989&products_id=37024
Fancy 120mm Corsair kit:http://www.performance-pcs.com/cata...oduct_info&cPath=59_202_989&products_id=36520
I'm not the one to ask.....I custom watercool everything.
A 670 is believed to run Skyrim better but a 7970 has more horsepower and overclocks well (for the most part), so as a card a 7970 is better.
As for your other question on the i7, I've a i5 3570K and I'm not sure if the thermals on these are different, i.e. can the same set of coolers deliver the same performance for these CPUs. If they do, I can vouch for Hyper 212 EVO. This is a good cooler may not be as good as Full Watercooling but comes close. You may also look at the H60 series of coolers (closed Water loop for your CPU) provided these are compatible.
Skyrim will run better on Nvidia stuff from the stock settings however with a little coaxing in the right way(skyrim tweak and tools easily found in steamworkshop) changes that experience quite fast. 7970 is more powerfull also more power hungry, though even if not using insane resolutions it would allow some more "tweaks" for games like skyrim where you could and can bring nearly every card to its knees.
Hyper 212+ no need for the EVO really not much difference between them, get an extra of the stock fan can also make a decent difference, and is a small cost anyways. There is better aircoolers out there for sure, but, this is virtually the lowest cost, quite excellent performer for its price range and above. Scythe Ashura, NZXT Havok, Phanteks also make many decent ones.
As for the 120 fitting in a 140mm space, provided there are holes for the 120mm mounting you will not have a problem. They do sell 140mm AIO coolers though, such as NZXT Kraken X40, Corsair H90 as well http://koolance.com/120mm-to-140mm-bracket-adapter is stuff like that if worse comes to worse, though I highly doubt the fan hole is only sized for 140mm.
With the proper drill bit and a dremmel, anything fits anywhere.....;)
7970 is faster, no questions asked. I would not hesitate to get one if I was looking for a single GPU in that price range. I've had a handful of them and they were all great cards.
CPU cooler, a Hyper 212+ might work ok for a lower overclock. I tried one on my i7-980 and it didn't work well at all, even with the fan maxed I could only get a 4.0ghz overclock so I switched to an H-60. The 1366 chips run pretty hot when you start adding voltage, remember it is a 130W CPU not a 95W or 77W like SB/IB.
he was only looking for a moderate OC, not a top one. There is many cpu coolers that are more powerfull/capable then the 212+/212 EVO, up the price $20 or so and there is much better performers, IB apparently does not play nice with some coolers as even though lower wattage the power climbs quite a bit when pushed beyond a certain point and the hot spot is more confined vs some of the older gen that had a higher heat output but over a larger area(I use the wording I have seen used elsewhere)
H60/H70/H80 or better would be perfect but is more costly, Be Quiet! Shadow Rock Pro SR1, Dark Rock 2/Pro 2 among others, Akasa Venom Voodoo, Phanteks PH-TC12DX are a couple that are much better performers of course.
As for the drilling holes, well, you cant fill holes back in :p, all my cases that had 140mm were 120/140 you use as you see fit, but yeh, not hard to put a washer there if need be lol.
if you planing to keep your 1080p monitor solution and not go more than that.. go with the 670. the 7970 its a more powerfull card but only on resolutions passing the 1440p. also as more powerfull card require a more powerfull PSU and its really hungry in the matter of power use... also NVIDIA provide better drivers... do not worry too much for skyrim even a 560Non TI can perform skyrim on the 1080p@60FPS maxed (I know for experience cuz my little brother have one of that).. the 4GB will not help much with the actual games.. but in the near future with the new consoles gen arriving will be nice to have large amount of vram like that..
for the matter of overclock. as people said a cooler master hyper212+ or cooler master N520 will do a good job handling you to the 3.4-3.5GHZ but not overpass that number.. also that number its a huge increment on performance over the 920 that chip scale well with the increase of speed.. should be fine.. at that speed..
that depends on the "mods" being used. If not worried about this, then the 7970 is wasting power and is to powerful for nothing. Nvidia sometimes has better drivers, but not always everytime, just on average better.
Yes its more powerfull not mean better if not have a good driver that support that.. Or if the game are not pretty well optimized for the card, that power will only be usefuil on huge resolutions.. On lower resolutions 670 play equal on some games, and better on vastly majority... Also more cooler card and less power hungry... Thats a thing to take in mind..
If have had both a 670/7970 and currently have a 7970. The 7970 is the clear winner here. With the current 13.5 beta 2 drivers fixing almost all latency/issues ( I haven't had any since 13.1) I see no reason not to get the cheaper, faster, better solution;7970.
Now if you are planning to go SLI/Xfire that's something else entirely.
Toss in another vote for the 7970. I chose it for my personal machine and wife's. The drivers seem to be updating nicely.
If you care about noise the Asus GTX 670 is extremely quiet.
If you care more about performance the 7970 is more powerful.
7970 is more powerful than even a GTX680.
nope.. ins't more power powerfull than a 680 in the vasty majority of games 680 perform better than the 7970... only games designed almost specifically for AMD cards, 7970 perform better.. most simply have to go with the 7970GHZ edition to have a decent advantage over reference 680.. but to compare both card at that point should be compared 7970GHZ edition/core edition vs a ASUS 680 TOP/EVGA 680 FTW Signature 2/MSI 680PE OC.. and in those case the 680 win... 7970 have a clearly advantage only on compute apps...
aww, I feel bad for nvidia now :(
Even @$40 off with a newegg sale, the 7970 is still a better value than the 670?
The 670 is $393 on sale
The 680 is $560
The 7970 is $400
The 7970 ghz is $460.
I'm comparing dollar for dollar. The 680 is $100 more than the 7970 ghz! So if the 7970 is STILL the better card, AND $100 cheaper....
That's why I was comparing the 7970 base to the 670, same price point.
Ghz edition worth the extra $50?
For that matter, maybe just a 7950.
Sounds like a plan.
I have a 7870, and on "ultra" sometimes skyrim, tomb raider will fall below 60fps; so I've turned them down to 'high'. Looking forward to keeping them on ultra, and keeping the next generation on ultra, too.
I'm building a computer for a friend, so I'll likely sell him my 7870 and upgrade myself.
Also, several times a day the screen will flicker white for a moment-- usually just browsing the web (like just now, writing this reply). Someone told me that was a driver problem, and should be resolved with updates going forward?
The 680 is $560
The 7970 is $400
You get charged a premium for non-reference 4GB cards for sure, basic 2GB 680's start at $459 and the 670 starts at $359. Still a little overpriced especially on the 680 but people buy them all the same.
yeah thats true but well.. this always has been the business with nvidia sell more expensive cards.. that not a secret... thats why i always prefer to buy mid-high range when out and a later time upgrade to a SLI/Xfire setup.. and still keep performing better than the best high-end.. :)
As far as the Cooler is concerned. Since you have a 140mm slot check out the nzxt kraken x40. It is a 140mm cooler that would go perfect in that single 140 mm slot.
Ahh the age old 670 vs 7970 Debate. A simple tread search would have returned 100+ results since it is always an hot issue.
Anyway, In the last year I've owned (in order) ASUS 7970 top, EVGA gtx 670 ftw, and now Crossfre xfx 7950.
When I bought my 7970 last summer, the smoothness was off. So I sold it an bought a 670 ftw. The 670, at the time, out locked the 7970 and was a monster oc'er. Now I have gotten into bitcoins mining so I returned to 7950s.
Single card experience seems to be a lot better now. But crossfire has well documented issues.
With a ton of mods at 1440p I hit the 2gb limit of my 670 in skyrim often, but never saw performance take a hit.
I think at 1080p you will be fine with either car. I would pick the 7970 simply because I believe it is a better value.
You know the 7970Ghz edition is just a 7970 overclocked a little. The 7970 is faster than the 680 unless you are stuck in the middle of last year where the 680 was slightly better. The 12.11 drivers for AMD were a huge boost to performance.
Faster card, cheaper card and with a great bundle of games. It has to be the 7970.
There are only two situations where I would get the 670 over the 7970 and that is if I was considering 3D gaming in the future or going for a dual card setup. Crossfire still is weaker than SLI at the moment.
I always have the impression that AMD as a single card solution have better hardware but their driver is limiting it. That being said, I think when the maxwell graphic card comes out and nVidia no longer optimise games for the Keplar series, the 7970 will win in most games compared to a 680 just because it has more raw potential power in it.
I would go 7970 on that one. But if you had the money get a 680, but prices will be coming down soon. Rebates already there.
