ASUS 660 TI Raise Voltage?
Is there a way to manually set a voltage for this card? I know with Kepler cards they just have a power target and core voltage but that doesn't allow to set a specific voltage. Is there a modded BIOS that will allow me to do it?
nope you can't manually change the voltage. all you can change is the power target.
I'm surprised nobody has yet to figure a way to raise the voltage either by a modded bios or other means
