Replaced an MSI 4870 512 OC with the ASUS Dark Knight for the increased video RAM and better cooling, lower fan noise. The stock cooling of the MSI, especially the fan noise, when trying to lower temps by increasing the fan speed was terrible, a much noted complaint. The Dark Knight improved idle temps from 58-61 C on the MSI to 39-41 C. Fan noise was vastly improved, but case temps went up from 73-74 F to 77-80 F, apparently from the open air flow design of the ASUS Dark Knight opposed to the closed stock cooling. Have good air flow in your case, when running the 4870's in an open cooling custom solution.
My problem is that I used the ATI Overdrive on the card, which boosted the GPU to 880 from the stock of 750 and the video RAM, memory to 1280 from 900, this was done without any restarts and temps were just below 60 C maximum with the fan on software Auto or default. I ran this way for several minutes, saved a profile of the Overdrive settings and a second profile of a much more conservative OC, that tested fine and returned to the default settings. This is when I noticed the GPU speed was down to 500, instead of 750. Any and all attempts to adjust settings, has the GPU returning to the 500 speed with the adjusted speed lasting no more than a second or less. GPU z confirms this card will now only run the GPU at 500.
