Asus 290X Matrix Platinum overclocking
They put the big shroud on it to disguise the fact that it's the same DCII heatsink as every other card.
Also you have this card and the 780 Ti Matrix? :3
Perhaps better binned, though? If it's the same cooler the VRM cooling will be appalling.
Heaven h20
Matrix's LN2 bios max settings on GPU Tweak and XCB board
Asus Tweak tool works on all 290/290x GPU's?
Can you increase voltage with it? and by how much?
Not THAT impressive considering i beat your Firestrike on my ref 290x without tessellation disabled lol
Do you have a FM link for your run?
http://www.3dmark.com/fs/1881409
All watercooled, not entirely sure what i could do on LN2, dice or phase.
That's an awesome 3930K and nice gpu ranger:)
Heres LN2 test with cpu @ 4.8Ghz and no blackscreen
I will test with cpu @ 5.9Ghz+ next
So far @ 1.497Vgpu
So far @ 1.497Vgpu
Now those are some impressive clocks, do a 13.12 WHQL run with tess enabled for valid score :D. And give it some volts man, i put 1.63v through my ref 290x on water!
