Assassins Creed Bro - Controller Issues
Drakenfeng
Just finished up AC2 and started playing AC:B and having controller issues that I wasn't having in AC2. Actually the controller itself works perfectly fine, but all of the actions in the game are missing the button icons so when it tells me "press _ to do x" there's nothing there. Fortunately I've memorized most of the controls but this really thew me off already during the intro sequence where you're supposed to hit a button for the quick time event but the button was invisible (only figured it out after watching the camera spin around for a minute).
Using a PS2 controller through a PS2->PC converter, which worked perfectly in AC2. It even matched the correct PS buttons (triangle, square, ect) instead of xbox ones. AC:B does lists the buttons in properly the bind menu but in text form (triangle, square). Unfortunately there's no icons there either.
Okay I found a generic xbox controller and plugged that in and it displays the icons properly - is there a program that will make my ps2 controller look like an xbox controller to AC:B?
