LigTasm
- Jul 29, 2011
I'm working on a build for a friend, he had this board and a 4770k new in box for months now and decided to have me build him a rig.
Here is the problem, I cannot get a discrete GPU to work with either of the x16 slots. Plot twist: the slots work and detect the GPU just fine, or any other card you put into them. The machine will boot into windows with the GPU in on a black screen.
The onboard video works perfectly, with no issues. However, nothing works in the slots. Is this a board problem or a CPU problem? I tried a sound card in both slots, works fine. Tried a pci-e x4 SATA card, works fine and runs hard drives. GPUs are detected by windows, you can install the drivers and everything, but no output.
If I change the BIOS to PCI-E gen 1 or 2 like many suggest it makes no difference. I have updated to the latest BIOS.
Any ideas?
Any ideas?
