ASRock Z170 USB Settings
PiERiT
I bought a new external hard drive yesterday and it has a very bright status LED on it. It doesn't bother me at all during the day, but when I power off my machine at night and try to sleep the light stays on (flashing) and literally illuminates my whole room.
My assumption is my board is still supplying USB power even when turned off. I looked around in the BIOS for an option to disable that and did not see anything, but I could have overlooked it. Is this setting usually called something in particular?
Black electrical tape is your friend. I have those little black squares all over the place covering all kinds of annoying LED's. Caves and LED's don't mix.
That's what I ended up doing. Somebody on the ASRock forum suggested the "Good Night LED" option in the BIOS but that didn't do anything. Oh well.
Look in the BIOS for ErP/EuP support and disable it if it's enabled.
Also look for anything that says 'USB charging' and disable it.
Also look for 'On/Off Play' and set it to disabled. <--- Particular to ASROCK
Also look for 'Deep SX' and set it to ENABLED. <--- Particular to ASROCK
black tape here, if i did not have it the room would look like mission control or something.
