novadaemon
- Aug 24, 2006
This is a pretty straightforward problem.
If spread spectrum is disabled on my board my board will do a double cold boot.
Ok, fine... Enable Spread spectrum.
If spread spectrum is enabled on my board everything will be fine but my BCLK will run at 99.8mhz instead of 100mhz.
No problem. I just need to push my BCLK to 100.1mhz...
Big Problem. My PCI-E x1 Intel NIC drops from the system entirely.
What can I do to fix this?
Edit:
Just did more testing.
100.1mhz drops the NIC
100.2mhz drops the NIC
101mhz drops the NIC
100mhz keeps the NIC but then PCI-E run at 99.8mhz
99.9mhz runs at at 99.9mhz but it also drops the NIC
99.8mhz runs at 99.8mhz and also drops the NIC... (wtf?)
100mhz with SS Disabled will keep the NIC
100.1mhz with SS Disabled will drop the NIC
Edit:
