Hi, having issues with a new Sandy Bridge build. I'm on my second board and have swapped out several parts but still have some troubleshooting to do. Hoping for a few pointers in case I'm overlooking something obvious.
Problem: Computer powers up fine, all fans and system are functioning. The monitor is seeing no video output, I get a "no output from DVI" message.
I'm on my second board, had the same exact result with an Asus P8P67 LE.
CPU: i5-2500k (new)
CPU fan: Coolermaster Hyper 212+ (new)
Mobo: ASRock P67 pro3 (new)
HDD: 128 GB Crucial C300 (new)
RAM: A-Data 4x2GB DDR3 (new)
PSU: Seasonic X-650 (new)
Case: CoolerMaster HAF 922 (new)
Video: EVGA GTS 450 (new)
So far I've tried:
1) Cutting down on memory sticks, moving a couple around
2) Reseating memory
3) Reseating video card
4) Swapping video card out with EVGA GS 7900 Go
5) Replacing the motherboard
6) Reseating video cables (and hooking up DVI-to-VGA also)
I know the monitor is functioning, and I also have a spare I can try later. Likewise I have a Corsair 620HX PSU I will try out. At no point with this new rig have I ever been able to get a signal to the monitor no matter what I do, not even once. I do have a case speaker up but get no beep codes whatsoever. I'm wondering if it could be a bad CPU or non-compatible memory?
Any troubleshooting suggestions would be greatly appreciated. Thanks very much.
CPU: i5-2500k (new)
So far I've tried:
2) Reseating memory
