I've just installed the above mobo, along with 1Gb DDRII 800 & Athlon 64x2 5200.
I'm also using a Gainward 6800 GS+ Bliss gfx card.
After fitting the new board then powering up, nothing happens.
The CPU & GFX card fans spin up to speed.
There is no hard disk activity at all.
There is also no video-out from the gfx card.
So I cannot even get [F2] access to the BIOS during the power-on-test to check the hardware status.
I've checked all connectors are in the pushed fully home in the correct place & all jumper settings on the board are correct.
The mobo is also powering up directly from switch on at the PSU, not the power on button on my front panel! (I have checked the power on button jumper is fitted correctly)
A fellow Hardforum user - rincewind - had the same problem last year, I've included a link to the archived entry:
http://www.hardforum.com/archive/index.php/t-1095436.html
If anyone can help, or knows a solution it'd be much appreciated. (especially if rincewind reads this!)
If it's a faulty board, I'll just return it to the seller.
Cheers in advance.
Cheers in advance.
