ASRock 939Dual-SATA2
darktiger
[H]ard|DCer of the Month - April 2007
Just wanted to share something to those who have this awesome board. It works with a XP120 just fine. :)
Nice setup ya got there. I perfer to keep my 939Dual-SATA2 a bit on the wet side of things...
BTW...any reason why you are running your ram in single channel instead of dual channel? Put your ram in slots 1 and 2 to be in dual channel configuration. :)
I know. If you look closely there is a stick of ram between slot 1 and 3. I only have 2 512 and 1 1gb. Still waiting for another 1gb stick. BTW can you run different brands of memory in dual channel?
Normaly NO unless you get extremely lucky, Matched sets work the best............. :D
Could someone give me their take on this board? A friend of mine is looking into pairing this with an X2 3800+ and moderate air cooling, and trying his luck with OC'ing.
Have any of you overclocked this? How successful was it? :)
if i remember correctly, theres not very much of an option for vcore voltages... but i guess theres a volt mod out there somewhere?
