I can report that Vista Ultimate works fine with my set-up. Vista does a fairly good job of setting up the ULi motherboard options. Had a problem with my LAN connection (not detecting Internet) but I installed the Uli Beta driver for the Dual-Vsta motherboard instead and it works fine now.
The only problem I've found so far is there is no option for the processor power management under Control Panel - Power. It should be available under the Balanced option. I have Cool n' Quiet enabled in my BIOS, the latest mobo BIOS and have the latest hardware driver for my processor from Windows Update Drivers. AMD say the CnQ is built into Vista but it sure doesn't work on this motherbaord. I tried using the XP driver for CnQ running under XP compatibilty mode but it only installs one core. Although the power management option is now showing under the power scheme.
Does anyone know how to fix this? Are AMD or Microsoft going to correct this with a driver? Asrock have said they will not be releasing anymore BIOS updates for this motherboard. So much for having a greener CPU!
