ASRock 939Dual-SATA2 Problem
vinceboi
After putting everything together, nothing seems to work. The fans turn on for a second and then just turn off. It's not the power supply because I've tried it on another computer and it works fine. Does this mean a dead board and I should go ahead and RMA it or is there a way to fix this?
Have you connected the cables from the power supply to the motherboard? - both ATX 12V Power Connector & ATX Power Connector. 2 & 4 in the manual. Also have you connected (19) Chassis Fan Connector for the PSU? If that doesn't work reset CMOS by pulling the battery out.
My money is on Vince. I know the manual says NOT to connect both power connectors but you have to. (At least that's what I remember reading.) I experienced exactly the same problem.
Connect both cables.
In addition, did you do any custom wiring?
Unplug EVEYTHING except the mobo, RAM and CPU fan... Remove your GPU and everything. Start up... Does it stay on?
eh i rma'ed the board hopefully the new one works, thanks for the help though.
Exactly the same motherboard. Was working fine last night. This morning, it was turned off (when I'd left it on before bed). The power button does nothing. Pulling and replacing the power to the motherboard (not the 4-pin) makes the CPU fan spin for a second, then nothing.
This is my second version of this motherboard. I had a circut breaker go (I had a space heater plugged in on the same circut) and the computer stopped booting.
I am going to try a different power supply tonight, and unplug anything that isn't needed.
Damn I really hate computers some times. I might get a call from work in the middle of the night with a support issue and I'm going to have to drive in to the office.
My apartment lost power sometime over the weekend, and the computer never came back on after the power was restored. I tested my power supply, unplugged and replugged everything on the board, swapped out memory, and nothing worked. Reset the CMOS, nothing, unplugged the battery from CMOS, still nothing.
Is there any chance that the board can be fixed? I've only had it for about 6 months, and that seems like a very short lifespan for a motherboard. Anyone have experience dealing with Asrock on warranty issues, or just give up on the board?
I got it because I wanted to milk a few more months out of my AGP video card, but I guess it's time to upgrade the mobo and video card.
Just wanted to vent :)
Emil
Emil,
I played around last night with the computer, and discovered a few things.
If I had everything but the video card plugged in, and I pulled the power connectors from the motherboard and re-attached them, the computer would start.
If I plugged the video card in to it's secondary power, and restarted the computer, the fan would spin for a second and then nothing.
If I removed the power cable to the video card, and hit the power button, nothing. I have to remove the motherboard power cable and plug it back in before I can try again.
I confirmed this with two different power supplies - OCZ 520 watt, and a Thermaltake 430 watt (brand new that I borrowed from work).
The question: is it a $90 ASRock motherboard, or a $700 video card?
Very tough to test, and ASRock is going to blame EVGA and EVGA is going to blame ASRock.
I guess I need to pick up a second video card (PCI express) and see if it's the card or the motherboard.
Emil, try that out - it might not be your motherboard.
David.
