ASRock 939Dual-SATA2 OC
darktiger
[H]ard|DCer of the Month - April 2007
For those who have this board and the X2 3800+, what OC speeds are you all seeing. I went from 2.0 to 2.41 without any problems....I am using the XP120 and my temps are exactly 40°C after 1 hour of burnin....
2.5Ghz @ 1.3v (stock volts) 40C no load with a Zalman 7000 :)
I dropped it back down to stock because XP 64 was having problems even though XP 32 was rock solid :(
Yeah I noticed that with my A64 3200+. When I went to x64, I had to drop my oc from 2.67 to 2.40 :(.
do you think that was mobo related, or OS related, I was thinking about getting x64 but Ill reconsider if it isn't stable.
OS most likely, not sure though.
