Asrock 7900xtx
kwikgta
My AsRock Phantom Gaming 7900xtx with the 550w bios, just installed and tuned it in today. Still on the stock cooling for the moment. next mod will be to de-shroud it, 3d print a mounting plate and install some 120mm howler fans on it, but very pleased so far!
Just curious why did you choose to go with another 7900 (judging from your sig, you already have one) over the 9070's? VRAM?
Sig was way outdated but i was offered this one for $800, already flashed and with 7950 pads. I made a few quick calls and sold my old one for $800, So I broke even and didn't have to fool with flashing it.
Why not water cool it with this? Water cooling my 7900 increased my under volt capability substantially for sustained higher core clocks. Can't speak to maxxing it out above 400 plus watts though.
Yes I've looked at that block before. Honestly, I want to see how far I can get on air first.
Water is always faster and cooler. The problem is adding the extra loop and weight to the system.
I can understand wanting the convenience of air though. What temps are you getting on the 7900 XTX when you Furmark, do game benchmarks, or run vigorous stress testing?
Not good. Hotspot is 95 and v-ram is 76 with fans at 100%
Today I swapped out the 105cfm Phantek fans for some 130 cfm Ice-Gale Thermal Xtra fans on my AsRock 7900 xtx with 550w bios and moved to #29 on the 9950x3d/7900xtx top 100 list. The fans lowered my temps to 84c on hotspot and 72c on v-ram. The chip on this card is golden!
I run an asrock liquid 7900xtx. Its damn fast. Pulls 525watts or so. I just repasted waterblock with phase change material. Gpu hotspot went from 110c to 60c under full load. These cards will dry out so repaste with ptm in my opin.
Same here on my XTX. I don't push it that Hard though cuz replacement would be near impossible. What's your steel nomad score with that beast?
Im not pushing it. It just runs that hard naturally. I can push it more but the gains are not worth the stress on the card. I average about 425 watts though peaks have hit mid 500s. Having a custom water loop pulls so much heat out of the card. As long as its possible, I will always custom loop my builds.
Edit* im.also using the official asrock bios that is more aggressive though I am tempted to flash back to the regular bios since the card is older snd as you say replacement is nearly impossible even though im still under 3 year warranty.
