Asrock 775Dual-VSTA users read
PornoSatan
Any of you having issues with this board using a C2D and DDR400? I have the latest 2.90 bios. At stock speeds with my E6400 ( 8x266 ) I cant pass Prime95. This is with 3 different DDR400 sticks. If however I lower the FSB to 261, I can. I'm curious as to what other people are experiencing. What I find especially peculiar is when you load defaults, the bios sets the FSB to 255 instead of 266.
If you have this board and some DDR400 laying around, could you throw it in to confirm/deny its an issue with just me? I find it hard to believe all 3 of my sticks are bad, and tend to think its more of a compatibility issue between the board and DDR400. Also, what do the memory voltages signify? Options like "Low" "Normal" and "High" doesnt tell me much if the boards definition of 'High' is 2.3v when the ram is supposed to run at 2.6v for example.
For comparison purposes, here's the 3 sticks of ram I tested/use:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820141424
had the same board for over 6 months with e6600 running @ 300fsb with ddr 400 had no problems with the board i just stuck the voltage setting to high and the memory to 333 in the bios
once it was clocked to 300fsb for cpu the dividers took the memory to 390mhz and i ran 24/7 rock solid
sounds to me like you need to try volts on mem on high and try clocking to 275fsb with mem either set to 333 or put flexi option enabled in bios
if still no go you got a duff board or duff mem
That's the whole issue right there, I can easily run the memory at 333, and its funny because thats what the board defaults the ram to when you set it to "Auto". But if the board supports DDR400, it should run it at DDR400, not DDR333.
Check out the following link for alot of info on this board ...there are 3 different (Vsta Dual, Vsta Quad & Vsta Quad Sata2) versions. You should find what you're looking for & much more. (Hint ...this board has auto Memory dividers depending on the FSB chosen & whether you use DDR1 or DDR2 memory) :D
http://forums.anandtech.com/searchresults.aspx
Edit: Thought I'd add the below from the above Link.
Memory dividers are not able to be set manually and work automatically depending on your ram type, speed and the FSB you set it at.
This is how it works on previous motherboard models and should apply also to this motherboard.
http://forums.anandtech.com/me...AR_FORUMVIEWTMP=Linear
At 222FSB DDR400 is at 1.1 divider
At 267FSB DDR400 is at 4.3 divider
CPU SPEED MEMORY Mhz FSB/DRAM Ratio
With an E4300
1800 (200x9)
DDR266 133 3:2
DDR333 167 6:5
DDR400 200 1:1
1900 (211x9)
DDR266 141 3:2
DDR333 176 6:5
DDR400 211 1:1
2000 (222x9)
DDR266 148 3:2
DDR333 185 6:5
DDR400 222 1:1
2100 (233x9)
DDR266 117 2:1
DDR333 146 8:5
DDR400 175 4:3
2200 (244x9)
DDR266 122 2:1
DDR333 153 8:5
DDR400 183 4:3
2300 (256x9)
DDR266 128 2:1
DDR333 160 8:5
DDR400 192 4:3
2400 (267x9)
DDR266 133 2:1
DDR333 167 8:5
DDR400 200 4:3
2500 (278x9)
DDR266 139 2:1
DDR333 174 8:5
DDR400 209 4:3
2600 (289x9)
DDR266 145 2:1
DDR333 181 8:5
DDR400 217 4:3
Good read about RAM here on previous model motherboard.
http://www.anandtech.com/mb/showdoc.aspx?i=2810
This below extensive thread has it all that also applies to the SATA2 Mobo.
