Asrock 775 VSTA Memory Dividers
Javvis
I've only built/overclocked Socket A systems in the past ...but, I recently built a system using this board with the following.
1.) 3.0 ghz Cedar Mill.
2.) 2 sticks 256mb Geil 3500 sticks memory.
I set the FSB to 233 & the memory to 200 ...& it booted up at 3500 mhz without any increase in processor (30 C) temp.
I noticed while using the newest version of Everest ...that my Memory was running at 217 mhz & the memory/FSB divider was 6/8. I've always thought that it's better to run 1:1 or possibly 1:2. (Flexibility option is turned off)
Could someone please explain this memory/FSB divider thing for this board in detail using my setup with DDR & also if I switched to DDR2. I've looked elsewhere & could only find minimal info regarding this.
if u bought this mobo for overclocking u made a mistake moderate overclocks with bad memory dividers.
u got it set abt as high as that baby is gonna go i had ddr400 running on this mobo before i changed mobo had to set fsb in bios mem options to 166 to get it to run @ 395 effective u already got above 400 so be happy this is a limited board with limited features that will allow u to upgrade as cash allows.
with this board i had an e6600 @ 305fsb and it done a good job let me go upwards without my bank balance going to far south
I was in a hurry earlier & thought I posted this in the motherboard section ...Sorry. However, I really love what this motherboard can do for the for the price & have bought 9 more.
I know it doesn't overclock as well as some other boards ...but, for now I can use my DDR memory & AGP cards. I just need to know how the Memory/FSB settings work.
Hopefully ...I can post this in the proper section here to possibly receive the needed info/help.
I have this mobo as well, i find i get frequency noises from around the cpu socket under different loads though, any idea what might be causing that?
I'm running a3.2 precott in mine with a 7300GT seems to go great apart from that noise issue.
About your divider, i'd relax the timings as much as you can first then find the cpu ceiling first, then bring your ram up as best you can after that, thats what i'd do personally.
