ASRock 3d Vision HTPC
I've used the old ion330 and they played bluray ISO without any problem. I just picked up a Vision 3D with bluray yesterday and hope to set it up this week. With bitstream HD audio it should be perfect for a HTPC. I went with the cheaper i3 model, since the ion worked so well, didn't think I'd need anything faster to just playback blurays over the network.
I just set mine up last week and it's a very nice unit. The packaging, design of the system, and build quality are all top notch. I sort of expected to run into a bunch of problems since PC hardware never works right, but to be honest I was surprised and didn't run into a single problem.
I got mine from newegg for $759.
http://www.newegg.com/Product/Produ...18&cm_re=asrock_vision-_-56-158-018-_-Product
If you have any specific questions feel free to shoot.
