Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
There are ASR-5805Z on Ebay for under a hunder. Is this a good choice for a home server/NAS that will use Snapraid? Or should I just stick with getting a serveraid?
Unfortunately even @ the low price of 100 dollars I personally don't think it's worth it for any kind of JBOD setup. That particular model is very picky with SATA drives, runs extremely hot and Adaptec's JBOD implementation on the 5 series is kinda funky. It's also a bit outdated. If your just looking for a simple HBA, you'd be much better off with an IBM M1015 or something similar.
