Aspire Case Question
The front should come off really easy, there are 4 screws in the interior that have to be removed, and then just squeeze the pop outs and the front should come right off. I would not ziptie as there is the whole vibration thing to contend with.
But yeah, you CAN zip tie anything.
Thanks for the advice. The only problem is Im having a hard time trying to squeeze the plastic standoffs. The only reason for the zip tie is I wanted a 92mm fan for more airflow but there are only standard 80mm holes in the front.
