My brother's PC just crapped out for no reason. It was working fine when he was at college. He drove 5 hours through Ohio, got home, plugged it in, and when he went to turn it on, all the lights and fans powered up for half a second and then immediately powered down. Then, everytime we pushed the power button after that, nothing would happen.
So we unplugged it and plugged it back in. Pushed the power button...everything turned on for a split second and then shut back down. lather rinse repeat.
So my friend suggested to "re-build" it (just take everything out and put it back in). My brother didn't want me to completely dismantle it, so I just took out the RAM and unplugged all the molex connectors and then put everything back in the way it was.
Now nothing happens when I push the power button. The green light on the mobo turns on when I plugged the PSU in, but that's it. So if the mobo is getting power to turn the green light on when I plug the psu in, is the psu completely dead?
p.s. when I was cleaning out the tower, I found a little twisty-tie sitting on the mobo under some wires. Some of the metal on the twisty-tie was exposed, touching the mobo (i'm pretty sure). Bad?
thanks.
thanks.
