ASP.net Transfrom Memory XML and send output to client.
Skyruner2
So i am loading a base XML file. Modify this file in the memory, load an xsl that should convert it to a nice HTML page.
however, i have no clue as to how i can send the transfrom results to the client!
here is what im doing:
Code:
//the classes
    public abstract class XMLWorker
        protected XmlDocument xmlDoc = new XmlDocument();
        protected XMLWorker()
    public sealed class XMLPageCore : XMLWorker
        public XMLPageCore(string Path2BaseXML)
            xmlDoc.Load(Path2BaseXML);
            XmlElement selectedNode = (XmlElement)xmlDoc.DocumentElement.SelectSingleNode("General/Now");
        public void Deploy(string XSLTPath,System.IO.Stream Stream)
            System.Xml.Xsl.XslCompiledTransform XSLT = new System.Xml.Xsl.XslCompiledTransform();
            default: XSLT.Load(XSLTPath);
            System.Xml.Xsl.XsltArgumentList args=new System.Xml.Xsl.XsltArgumentList ();
            XSLT.Transform(xmlDoc.DocumentElement,args,Stream);
//The call
    XMLPageCore test = new XMLPageCore(Server.MapPath("test/XMLFile.xml"));
    test.Deploy(false,Server.MapPath("test/XSLTFile.xsl"),Response.OutputStream);
on the page though, i get the XML Processing Instructions <?.. and then all of the xml content w/o any tags or whitespace.
but if i use the overload of xslt.transform that will take the input and output files as parameter, it works just fine.
to be honest im really at a bit of a loss as to what is going on here!
I'm working on some ASP.NET XML this weekend. I'll try to find an answer for you too.
