ASP.NET Parser Error: Could Not Load Type "myApp._Default"
Hello,
I have been developing an ASP.NET application and have run into a problem I have not been able to solve for the past 2 days.
I build the application, and publish directly to our server using Visual Studio 2005, and the application works as long as I'm running it on my machine's localhost. Yet when I try to access Default.aspx on our server I get this error:
"Parser Error Message: Could not load type "myApp._Default""
I have been reading on forums and have tried everything suggested, rebuilding the application, deleting the DLL files and recompiling, and so on but nothing has worked.
If anyone has any other suggestions on how to solve this problem they would be greatly appreciated.
Regards.
In the "Publish Website" area.... What are the options you have selected/enabled?
Also, are namespaces in use throughout the app? If so, have you changed them at all at some point in time?
Generally speaking, this sounds like some content might be missing on the destination server. One possible cause is a missing application DLL file that is made during compile in VS2005. Look at the files on the destination server and see if any are missing (especially in the "bin" folder).
