I realize I will probably get no responses for this topic, because it's very unique, but it's worth a try. I'm about to scream at this thing.
I recently purchased a Z8NA-D6 motherboard and the ASMB4-iKVM card came with it. From what I understand, other Z8NA-D6 owners have experienced a bitch of a time setting this up on their motherboards, because it uses a shared LAN port (LAN 1), instead of a dedicated LAN port.
With that said, I set out on my own to configure this thing. I had issues getting it to show up at all, but I finally got it to the point where the motherboard could see it. I also applied a newer firmware to both the motherboard and the iKVM card. I can now ping it after assigning an IP address to the BMC LAN configuration under IPMI in the BIOS.
I attempted to connect to it using Asus Remote Console (ARC) from an XP machine. I can get it to show up in the list, but I can't access the actual remote console to manage it. I also can't see any of the other settings, so something is clearly not right here. It keeps saying "failed to connect" and it doesn't seem to take the default credentials. If anyone has successfully installed this card with a Z8NA-D6 motherboard, could you please list the steps you took to get it running? There is almost no information on the ASUS website concerning this issue and their support is worthless.
