Does this have an IPS panel in it or tn (don't know if this is pva are tn viewing angel specs) I can't find any other info other than this. Is it comparable to the nec 20wgx that has the 5ms ips?
Display Type: LCD display
Pixel Pitch: 0.285 mm
Display Area: 473.8 mm x 296.1 mm
Display Colors: 16.7 million
Vertical Refresh Rate: 60 Hz to 75 Hz
Horizontal Frequency: 31.0 kHz to 83.0 kHz
Input Video Signal: Analog 0.7Vp-p/75 Ohms
Speakers: 2+2 Watts
Audio Input: RCA L/R INPUT
Contrast Ratio: 1000:1
Brightness: 300 cd/m²
Response Time: 5 ms
Horizontal Viewing Angle: 85 degrees (TN im assumeing)
Vertical Viewing Angle: 80 degrees (TN I'm assumening)
Maximum Resolution: 1680 x 1050
Cabinet Color: Gloss Black
VESA Mounting Compliant: VESA 100mm
Unit Dimensions (WxHxD): 19.9" x 14.1" x 2.1"
Dimensions With Stand: 19.9" x 16.0" x 8.3"
Unit Weight: 11.0 lbs.
Power Consumption: 48W
Speakers: 2+2 Watts
Response Time: 5 ms
