[Ask]Water-cooling an 900D
omegasama
Hi everyone,
As you can see am new to this forum ,what brings me here was firstly reviews and secondly the photo galleries of all those superb water-cooling rig .
My case is still on pre-order and i don't know when it will be ship but anyway i want and i NEED the case to be water-cooled :D . I found the system that corsair made extremely attractive . https://www.youtube.com/watch?v=cn7lMu9rh9A&feature=player_detailpage#t=237s
So i found the list of the components that Corsair used ( below ) , but i want to add a Bay Res to it and convert the setup to a single-loop with :
2 x 480 rads
2 x Top
1 x Bay res
1 x Res
Asus Maximus 5 Extreme
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131858
Intel Core i7-3770K Ivy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Asus GTX670-DC2-2GD5 GeForce GTX670 2GB X 3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121637
CPU Block
http://www.performance-pcs.com/cata...t_info&cPath=59_971_498_490&products_id=34841
GPU Block X 3
http://www.performance-pcs.com/cata...t_info&cPath=59_971_240_579&products_id=35204
Top 480 Radiators (520x123x47mm)
http://www.performance-pcs.com/cata...t_info&cPath=59_457_667_668&products_id=26778
Bottom Left 480 Radiators (552x124x30mm)
http://www.performance-pcs.com/cata..._info&cPath=59_457_667_1075&products_id=33849
Pump x 2
http://www.performance-pcs.com/cata...e=product_info&cPath=59_201&products_id=24737
Reservoir x 2
http://www.performance-pcs.com/cata...oduct_info&cPath=59_318_659&products_id=35998
Front and Bottom Right 240 Radiators (278x124x30)mm x 2
http://www.performance-pcs.com/cata..._info&cPath=59_457_667_1075&products_id=34155
Fittings
BP G1/4 Black Matte 7/16 ID 5/8 OD x 25
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_614&products_id=26556
BP G1/4 Black Matte 90 Degree x 10
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_620&products_id=26764
BP G1/4 Black Matte 45 Degree x 10
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_620&products_id=26452
BP G1/4 Black Matte Rotary 90 Degree x 10
http://www.performance-pcs.com/cata...fo&cPath=59_346_393_611_629&products_id=27723
BP G1/4 Black Matte Rotary 45 Degree x 10
http://www.performance-pcs.com/cata...fo&cPath=59_346_393_611_629&products_id=26460
BP G1/4 Stop Fitting x 10
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_612&products_id=26450
BP Matte Black Dual G1/4 (22-31mm) x 4
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_766&products_id=35668
BP Matte Black Dual G1/4 (41-69mm) x 4
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_766&products_id=35775
BP Matte Black G1/4 Extender 15mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29802
BP Matte Black G1/4 Extender 25mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29808
BP Matte Black G1/4 Extender 20mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29805
BP Matte Black G1/4 Extender 30mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29811
BP Matte Black G1/4 Extender 40mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29814
BP Matte Black G1/4 Extender 50mm x 6
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_616&products_id=29817
Tubes 20 feet
http://www.performance-pcs.com/cata...oduct_info&cPath=59_413_292&products_id=24504
Draining Valve x 2
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_623&products_id=32810
Top Water Fill Set x 2
http://www.performance-pcs.com/cata...t_info&cPath=59_346_393_623&products_id=28425
Cables x 10 (Both)
http://www.performance-pcs.com/cata...e=product_info&cPath=34_289&products_id=26878
http://www.performance-pcs.com/cata...e=product_info&cPath=34_289&products_id=26879
Cable Management x 10
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=44_80&products_id=3207
Cable Management x 6
http://www.performance-pcs.com/cata...ge=product_info&cPath=44_80&products_id=26021
Powered Fan Multi ports (8) x 2
http://www.frozencpu.com/products/1..._Block_MMT-PCB-4-83.html?tl=g47c121s424#blank
Powered Fan Multi ports (5) x 2
http://www.frozencpu.com/products/1..._5xWay_Block_MMT-PCB-8-53.html?tl=g47c121s424
NB/SB Block
http://www.frozencpu.com/products/1..._EK-FB_ASUS_M5E_-_AcetalNickel.html?tl=g30c89
Dremel Grinding Stone x 4
http://www.amazon.com/Dremel-932-Al...4565740&sr=8-2&keywords=dremel+grinding+stone
Am asking for your helps here as this project will be my very first water-cooled pc to be honest am a total noob in this section. Thanks in advanced
Regards
The way you've formatted it makes it extremely difficult to follow. I also don't want to open up a new link to see what specific part it is. Can you list the components you have chosen?
What's your question? Just looking for approval of your parts selection?
  • What fans do you plan on using and at what speed do you plan to run them?
  • You really don't need anywhere near that much rad capacity.
  • Personally, I wouldn't touch anything EK-branded (ethics issue).
  • Mobo water cooling isn't necessary FYI
  • Why dual reservoirs?
  • My personal preference would be for a single dual-pump top rather than two completely separate pumps and tops.
  • I'd recommend tubing with 1/8" walls (3/8" ID, 5/8" OD or 1/2" ID 3/4" OD).
Non-water cooling related:
  • Why tri-SLI 670s? Multi-GPU systems tend to scale very poorly beyond just two cards even with multi-monitor setups. I feel you'd be better off with (2) 680s or even (2) 670s - either option would save you some money, too.
  • Keep in mind that the new Haswell chips are due out in just a couple weeks or so...
Good question.
With a 900d the usual though is "why not"
Also Koolance.
Why tri-SLI
Looks cool
Overall I think he wants this:
Ediiiit: Don't go black bitspower. I did. It is boring.
Go with red or white or some shiz
There's no reason not to go overboard with rads if you have the ambition and financial means to do so. It's more fun that way.
Either way, it's best to draw a diagram, however crude, to see what sort of angled/rotary fittings you will need.
I want my Case to look like this
But the image i posted is a dual-loop , with 2 x res , 4 x rads , 3 x GPU and MoBo cooling.
What i want in my case is ONLY :
2 x 480 rads ( http:///kZBfv , got something better ? )
2 x top pump ( something like this with 2 pumps: http:///Dpe6q )
1 x Bay res ( http:///ElDpB )
1 x Res ( http:///YvftM )
Tubing will be : 1/2" ID 3/4" OD
And for GPU i will buy the upcoming gtx 780 , CPU will be Haswell . Like i said previously , i want to convert the 900D from the picture to another setup ( mine ) which will be a single-loop. I really dont know what and how much fittings to buy ( rotary 90 degree /45 degree etc... )
Regards.
For a bay res I would actually go with a combo like the new Monsoon:
http://www.performance-pcs.com/cata...=37660&zenid=0f8f48607e0396af1e47f33a52ef846d
or
http://www.performance-pcs.com/cata...=37665&zenid=0f8f48607e0396af1e47f33a52ef846d
One is for the D5 while the other is for the DDC. I prefer the DDC model with a Swiftech MCP35X PMW pump and let the MB control it.
I personally have the Swiftech Maelstrom with dual MCP35X pumps connected to my MB for control. Really comes down to looks and I like the look of a temp display.
http://www.performance-pcs.com/cata...=35143&zenid=2c633683ae72eeef64364938d7586d02
If you want more bling then do something like this:
http://www.performance-pcs.com/cata...=36296&zenid=52a7b3a99695b9741687c7f92dd4c57c
http://www.performance-pcs.com/cata...=30775&zenid=52a7b3a99695b9741687c7f92dd4c57c
http://www.performance-pcs.com/cata...=30192&zenid=52a7b3a99695b9741687c7f92dd4c57c
(buy the parts separately and put it together yourself, saves quite a bit)
And then add a bay res like this:
http://www.performance-pcs.com/cata...=32045&zenid=52a7b3a99695b9741687c7f92dd4c57c
That saves space and still has plenty of power for the setup you are describing. A quad and triple rad radiators with Corsair SP fans will be plenty for the system.
The 900D will take quite a bit in it, so don't sweat the rads and pumps. I would stick to one loop, much easier to deal with and won't look crowded. Also, you could jump into using acrylic tubes instead of regular tubing. There is a great guide on overclock.net if you decide too.
Also, as far as fittings go, decide which ones you like, compression or barb, which brand, color etc. They all have their advantages and disadvantages, so figure out which look you like. For each block, you will need a pair. If you do a pump/res combo then two for that, separate pump and res then 4. Two for each rad and you might want a drain port, so then a T-line would be needed. Here is a pic of my old 800D to give you an idea of some of the fittings I used:
http://imageshack.us/a/img28/7279/dsc00011by.jpg
http://imageshack.us/a/img138/4993/dsc00008w.jpg
Hi , thanks for the reply.
But i think no-one gets what i want to say or i am saying it wrong ;) .I will try to explain it a better way .
I want to use the components I listed a little above. The fittings primarily, because there are plenty and I do not know what I must buy for a single-loop.
Essentially what I want to do is just copy the fittings / extensions / Rotary / Tubing etc ... of his setup and modify it in a single-loop to be mine, with these components:
2 x 480 rads ( http://www.frozencpu.com/products/1...EK-CoolStream_RAD_XT_480.html?tl=g57c597s1902 )
2 x Top pump ( http://www.frozencpu.com/products/1...Black_Laing_D5_Swiftech_MCP650655655-PWM.html with 2 x http://www.frozencpu.com/products/1...Pump_Module_-_PWM_Enabled_Single_Version.html )
1 x Bay Res ( http://www.frozencpu.com/products/1...Meter_-_Acetal_Black_CSQ.html?tl=g57c615s1939 )
1 x Res ( www.frozencpu.com/products/17509/ex..._Reservoir_6_Total_Ports.html?tl=g57c615s1940 )
1 x cpu block ( When available )
1 x GPU block ( when available )
Tubing will be : acrylic 1/2" ID 3/4" OD
regards
I think you are going to have to work that one out yourself.
It's too specific a question. You have as good an idea as anyone else if you want it to look like that corsair build. You just have to add up the fittings you see and make some assumptions about the ones you don't.
Maybe ask Jameswalt1 on Overclock.net
What he did was buy a mass (non specific) amount of fittings before he started.
Though that is very expensive.
Without drawing a very detailed 3D (or 2D, if you're good at visualizing) schematic of where you want the acrylic tubes to go, it is impossible to figure out how many of which type of fitting you need to complete a loop. Its taken me at least three weeks over multiple revisions to get mine right. James also did cheat by not bending acrylic tubes, instead using tons of rotary angled adapters which are very expensive.
Each 90 degree is ~$15
Each 45 degree is ~$12
So for every bend you make, your wallet cries a bit more. Of course, you can also invest ~70 in a heat gun and ~20 in a bender, which will save you in the long run.
James bought $ 1500 of fittings , and used only $700 of them as he stated in his thread . I cant see myself buying $1500 of fittings just to try out .But anyway thanks for all the reply i will figure this out by myself.
Regards.
