Asetek kit or DTek kit
RaGeWaVe
Alright i think ive come down to either the Asetek Waterchill kit or a DTek Flowmaster kit. Just wanted to hear if anybody had a prefrence from either or problems with one more then the other. thanks :D
be careful with the press fittings on the antartica cpu block. best thing to do is cut your tubes ahead of time, press them into the block fully, then mark the edges of the tube.
That way, when you're assembling everything and getting ready for your leak test, you can visibly insure that you've fully inserted the hoses.
On that block, they don't go in too far, and it is pretty easy to think you've got them fully seated, when you really don't, which equals LEAK.
