Asetek Hydor L30 II
nikoq
Hi all,
I am having a problem with the reviews of this pump.
1) Hydor L30 II with ½” ID hose barbs and
2) Hydor L30 II with push-on fittings.
Is it the same pump?
http://www.pcper.com/article.php?aid=44&type=expert&pid=4
According to this site there are two different ones.
Does anyone knows anything about it?
I want to order a Waterchill kit and I dont know what to do the pump, which I am going to get etc
Please help.
i dont see whats not to understand
"Stock Hydor L30 II with ½” ID hose barbs and Asetek modified Hydor L30 II with push-on fittings."
the Astek is just an L30 with 'push-on fittings'
is the same pump, just check out the waterchill website. You can order it with original hardware, which is the 1/2 inch stuff, or you can order with the press in stuff.
