AS5 on Mosfet?
Boostage
Is this safe? I am getting some copper heatsinks and was thinking of removing the thermal tape and using Arctic silver. is this safe seeing that AS5 is electro conductive?
As long as you keep it off the metal parts and just put it on the casing, it won't damage anything. However, just to be on the safe side, I would still recommend using a completely non-capacitive paste like Arctic Cooling MX-2, which will remove the slightest chance of something bad happening.
