cantankerous
- Nov 15, 2006
Has anyone actually noticed a difference if changing the stock thermal paste on an 8800 series card to AS5? I have never been one to find drastic differences in thermal paste changes unfortunately so was wondering if it is even worth it. If I did decide to give the cooler a good cleaning to apply AS5 is it the same small drop in the center only method as used with a cpu cooler? I would obviously only want to have to do this once and would actually like to see a difference for the troubles so it should be done right the first time I would think. If anyone has seen a difference, how much?
BTW, can AS5 expire or lose its efficiency? I have a tube here that must be at least 2-3 years old. It was barely used and is sitting cap side down on my shelf standing vertically. It has never moved but has been stored in a fairly warm room during it's entirety in my possession. I can't see this stuff 'going bad' but if so I would like to know to avoid using crappy paste which may have no lowering of temps or worse yet higher temps than the stock paste. I really hope I don't have to spend the money on another tube as this is 90% full but if I must than I must.
Thanks.
Thanks.
