When applying AS5 to a 9800 core, should you follow the "half a grain of rice" method for P4's or should you spread an even layer on the GPU heat spreader.
I guess, more to the point, is the GPU actually a smaller chip under the center of the heat spreader (like a P4) or is the GPU really that big?
