as ghetto as they come...
today i got bored and wanted to turn my external usb compact flash card reader into an "internal" one. i took a spare 5.25" bay cover, and hacked at it with a utility knife until i got a hole in it:
then i took those extra usb ports you get with your motherboard that come on a pci card, and took on off and hooked up my card reader to it:
now i need to get some hot glue or maybe super glue, so i can attach the card reader to the inside of the bay cover. as you can see, however, there are a bunch of chops on the front of the cover...and my cuts are real sloppy, so i don't think i'm going to even end up using this. if i could figure out how to take my reader apart (there are no screws) i'd vinyl dye the parts.
Qtip42 said:
......i came, i saw, i cried..........
i'm gonna have to agree with you on this one...
of course, you'd say the samy thing about the first blowhole i did, too:D
don't feel bad, at least it is functional... right?
dun feel so bad. i saw a pic where someone took an axe to a side of a case and duct taped a fan outside the hole.
No, no. To be "as ghetto as they come" you wouldn't of used a permanent marker as touch-up and left the beige showing...
But, as rogue_jedi said: at least it is functional
You should line the opening with band-aids to prevent cutting yourself...
i know someone that took his case and shot with with a 12 gague... put some nice holes through it... then he had a fan zip tied to the top of the case over some of the holes..
i had an offwhite keyboard and wanted a black one so i took a sharpie to it...
it dodnt look bad at the beginning but then it started to wear off :(
(bored college student)
