As always need help with a new build :)
draliko
Hi all, first thing bear with me for my bad english grammar, but it's not my native tongue :)
As a lot of people i need help designing a new SFF build, i'll first answer the required questions then i'll add a bit of background that i think can help.
So to the exam:
1. What will you be doing with this PC?
HTPC, 1080p playback + usenet, very light gaming (a la angry birds), normal internet surfing
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
Budget near 400€ all inclusive, not so flexible, cost it's a matter for sure :)
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
I live in Italy, no decent shops near my hometown, so i need to order everything online.
4. What exact parts do you need for that budget?
For the budget i need cpu, motherboard, case, psu, ram, heatsink (if needed), bluray odd. I only have a 3.5 hdd i hope to reuse
5. If reusing any parts, what parts will you be reusing?
As i said only the 3.5 hdd 500gb western digital caviar black
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
Standard features, usb 3.0 and sata. Don't need SLI or external graphic card. Hoping to make something small and silent.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
1080p on a 37" HDTV
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
Depends, i can hide it behind the tv or mount it in a closet space (about 43cmX25cmX36cm WxTxD)
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I know how to work with electrical wiring, never worked with metals.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
It is really important, but fanless is not mandatory, i will be at least 2 meters away from the htpc and with volume cracked up (i hope :D)
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
No mobility needed, after it's placed than that's enough.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Yes win7 license 64bit.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
I hope in the next 24hours :D
That was long :D I've done a bit of research and i thinked of a config like this:
Lian-li PC-q02 (with included PSU) or PC-q07
ASRock a75M-ITX
AMD a6-3500
4gb low profile ram (depend on what i find in stores)
LiteON Slim ODD BD Drive
I'm really uncertain about the PSU(if not included) and the cpu cooler.
I saw that the a6-3500 should be enough for 1080p playing with some filter and everyday use (maybe some bd rip once and then) and the tdp is not so high (65W), the big problem for me it's the case, i really like the lian-li ones style but i'm worried of the air flow (actually after seeing dm1179 build i'm less worried, fantastic build).
I will use xbmc and the majority of media will be played from internal HDD.
In conclusion i'm open to every suggestion, thanks for reading till here.! :D
A couple questions:
How do you plan to hook the computer to the TV? HDMI, VGA, etc?
Also, if you are going to hide the computer behind the TV, how are you going to access the bluray drive?
i will hdmi connected to a yamaha 5.1 receiver. I will need bluray just for ripping my bluray collection and occasional playing if a friend bring some movies :D
Silverstone SG05 is less expensive and has a superior power supply (you might prefer the looks of the PC-Q02/7) You can get them with 450W SFX PSUs.
Motherboard seems *ok*, I don't know much about AMD chips or mobos. It seems "low-cost", not sure if the price:performance ratio is there. Your call.
AMD A6-3500 comes with a heat sink and fan, no need for an aftermarket cooler.
4GB low cost, low voltage memory would be like: Crucial CT2KIT25664BD160B
Yeah, looks alright. If you're not getting a discrete card I would recommend getting one of the Trinity APU AMD chips, if they're out yet...
Hope this helps!
i ordered the pc-q02 and the asrock mobo, still uncertain about stock cpu fan, i'll see how much noise it makes, for sure i'll undervolt a bit the cpu, thanks all for the info :)
I'll keep you updated about the build! :)
