Hello community! I have just installed my TripleHead2Go, and upgrade that I have been anticipating for YEARS. However, all is not punch and pie.
The first game I loaded up, (Team Fortress 2) had an interesting graphical glitch: No Swimmable water.
It has been replaced with solid black. Shooting at it still makes a splash, but any attempt to enter it causes immediate crash to the desktop. Non-swimming water (water that is shallow, has no effect on movement) is rendered just fine.
I can actually play, and connect to servers, and have a jolly time, as long as I do not, under any circumstances, get wet.
Also, my refresh seems a little weird in my side monitors, when I have rapid movement, I see what appear to be Horizontal lines staying on the screen, demarcating regions that are refreshing at a slower rate.
If that makes any sense.
I have an AMD FX 2.8 Dual Core, 2 gigs of RAM, and an 8800 GTS.
My resolution is 3840x1024 in XP Pro SP2.
It sounds like a driver issue, so I removed my nvidia display drivers, then did cleaning using Driver Cleaner Pro, then restarted, and installed the latest official drivers, but the glitches remain.
Half Life 2, episode 2 runs without error,
Portal won't even start since I changed it's resolution.
I'm not sure how to proceed with my troubleshooting, any advice is appreciated.
