Dark Shade
- May 2, 2006
Okay, I've done a rather exhaustive search on Google and various forums including this one on this question:
Is there a difference between power usage and consumption between a PCI-E video card that uses a single molex power connection, and those who use a 6-pin PCI-E power connector? I've been having so many issues with my video card and one of the things I haven't been able to test with it is the power availability to the card. It uses a 4-pin style molex as the power injector. I'm pretty sure that the 4-pin molex have two grounds, a +12v rail and a +5v rail, and the PCI-E connector uses three +12v and three grounds.
My video card problem is this: It runs fine when using the computer for menial tasks like browsing and stuff, but the moment it goes under load from a 3D game it will artifact, lines and all, within a matter of seconds. I haven't totally ruled out heat but the nVidia control panel AND speedfan both say the core doesn't reach over 60C, whether they are correct or not I cannot be certain, but evidence suggests heat isn't an issue. My other idea is power... maybe my molex isn't supplying enough power? If I bought a PCI-E to molex adapter (not the other way around) would I be supplying more power to my card?
