Hi guys, I just purchased a Antec SLK3700AMB
http://www.newegg.com/app/ViewProductDesc.asp?description=11-129-122&depa=0
SP-94 alone with the Tornado 92mm fan, plus some Artic Silver 5 to cool down my PC a little, I have read the instruction for artic silver, but i still have some question might need you guys to enlighten me.
now i have the stock heatsink with the p4 socket 478 cpu, i took it off today and looked at it, it has those black pads that were originally on the heatsink, it has melted a little on the CPU too,
1. how do i get those stuff off the CPU? can i use a nail buffer and then use acetone to clean it? what is the best way to remove them?
2. after i clean the cpu, i just apply a thin layer on the SP-94 right? do i have to clean it then apply again like on the instruction?
3. i should just apply a little bit in the center of the cpu and let the heatsink do the pressure?
I also have the ATI 9800 Pro, how do i apply the AS5 on that too? thank you!!!
